This summer I put an impeller in this old style Sherwood pump (OE on my Oday 85) after seeing weak water discharge out exhaust. Pumped great for 4-5 weekends. Now the boat just sat for a month and today I fired it up. Almost no water discharge, but a look at the pump showed a lot of water coming out of the weep hole on flange bottom side. Doubt there is anything to do other than pull it off and replace or rebuild. Had Depco (good folks!) rebuild it in 2011 so I wonder if re-building again really makes the best sense. Thoughts on rebuild or replacement and,if the latter ,with Sherwood or Oberdorfer? (Engine is '85 Universal M-12).
