If you have a keyway there should be no problem with 'never seize' either on the shaft or on the flange. Enjoy the job.When installing a steel shaft coupling on a stainless steel shaft is it proper to grease the shaft or use "Never Seize" in the shaft to prevent freeze up? I'm leaning toward "Never Seize".
Thanks
I worked briefly with a yacht mechanic in 2010. We'd unbolt the couplings, back off the 2 pinch-bolts, then (hopefully) just tap the coupling off as someone pulls out the propshaft from behind. This is on freshwater boats, mind you. Re-installation is the reverse, then the engine mounts are loosened and the engine hossed around til you have < 4 mil gap between coupling faces all the way around.Split or full coupling? I always wondered (and still do) how folks with full couplings get those things INSIDE the boat. Anyone know????
