Sealant for Keel to Stub
Dec 7, 2013
97
O'day 302 Baltimore MD
I have read probably hundreds of posts now on the best sealant to use between the keel and stub joint. I have an O'day 302 1988 and am dropping the keel to inspect and possibly replace any bad keel bolts next week.
The yard is recommending 5200, but I am not so sure that is the best option. The advice I have seen online has been very conflicting.
Advice? I need to have something in hand by next week.
7,435
Alden 50 Sarasota, Florida
The keel joint is one of the few place most internet experts seem to agree is appropriate for using 5200
Feb 6, 1998
11,709
Builders use either a resin mix or 5200 generally but SikaFlex 291 or even 4200 work too. Nothing wrong with 5200 for a well installed keel.
PLEASE, PLEASE, PLEASE do us a favor and measure the physical thickness of the keel stub (fiberglass) on your 302 when the keel is out. Images with a tape measure clearly visible would be EXCELLENT!!
For example this is a Hunter 34 and while it is a fairly sloppy lay up (lots of non-wetted dry fabric) it is nearly 1" thick or three times as thick as the 322 I measured:
It seems some of these boats were built with stubs as thin or thinner than 1/4" and others considerably thicker. I have seen and personally measured a 322 at approx 1/4" which lost its keel.
I'd love to see one that is thicker, all we have thus far is hearsay, so we can chalk this up to a manufacturer inconsistency rather than a design problem.
Nov 5, 2010
99
Oday 23 Stonington, CT
Agree with Maine Sail on measuring stub (shoe) bottom thickness. VERY important. O'Day's late 80's bad corporate owners, lack of oversight, and probably stoned 16 year olds doing the lay-up has led to some near tragic situations. It should be THICK, with no cracks.
Dec 7, 2013
97
Maine Sail....
I will definitely take photos when I drop it. You have my word. I am anxious to see it for myself as well. I will sleep better knowing what is down there. Thanks for all the advice. I am very grateful for it as well as the DIY articles on your website.
I talked to Rudy at D&R and he seemed to think that the boats with a problem were the ones that were auctioned off in 89 when they closed the doors. Mine was not a part of that.
And I guess I will use the 5200 on the keel joint. It only worries me if I ever have to open it up again.
5200 is not impossible to remove, just very challenging, especially in tight quarters. There is a product Marine Debond that is helpful and an oscillating tool with the scraping blade can separate the 5200 from whatever it is attached to. The keel is easily accessible, so getting wedges or the oscillating tool in there is not a big issue. On other areas of the boat, this is not the case.
Jul 15, 2014
73
Oday 322 Freeport, Bahamas
When I purchased my 322 last year I was concerned about the keel sump thickness. I drilled down to the lead a few weeks ago and I have 3/4 inch of fiberglass and no leaks.
My boat is hull #35 and was built before the Leveraged Buyout of O'Day.
I was going to drop the keel this summer but the studs look fine so would be VERY interested in some pictures when you drop the keel.
My boat has now been in salt water for 4-years but hauled 6-months for three of those years.
Thanks,
Gary (Bahamas)
Dec 7, 2013
97
One more question...... (right....)
Should I use the fast cure 5200 or the slow curing stuff that takes several days? Any real difference?
Jul 15, 2014
73
5200 cure
Good Old Boats has an article that says fast cure has the same adhesion and strength as the regular product (7-days to full cure).
Nov 14, 2013
200
Catalina 50 Seattle
The slow curing stuff is much runnier. I prefer the fast cure, both because it's got the consistency of toothpaste and because it offers hours of working time, setting up nicely within a couple of days.
