Hi, Has anyone tried to re-caulk the scoop stern joint at the waterline? My looks to be getting very worn out, and the joint is underwater at times, especially when under power, so I want to make sure I don't get leaks.
It seems to be a rubber type substance, and as you know, it is quite thick in width.
Any thoughts on process and/or material to use?
