season greetings to all...please let me know your experience sailing only with the main, your oppinion and recomendations...my Genoa is damage.....thank You very much.
With the furler we are just the opposite and put the head sail out at times and don't put the main up. As long as we are moving we are happy and have even been happy just floating around.I single hand a lot and I guess I'm lazy too, cause I do it all the time.
It has to changer the balance of the boat but it doesn't mother me.
I expect that it doesn't head up as well but I'm not racing, just cruising around the bay so I'm OK with it.
Sometimes I don't even rig the jib.
except... if you rig the boat a lot - i.e., really use it as a trailerable. I’ve had both roller furling and a hank on jib and the hank on jib is a lot easier for setup and take down. I’ve kept mine hank on for the reduced setup time. My 26S is all around fast to set up (like 30 minutes), that is the tradeoff I chose.If you're going with one sail, a roller furling genny is the way to go
I have had a different experience than r.oril
I find my boat is a real dog with only the main. She moves some but I don't like it. It feels really slow and the feeling is just wrong. But even a very small storm jib and she really picks up. I've always assumed it was that "slot effect" thing you read about.
I think we would argue about what is the best color to use on halyards..
This is one of my favorite forums, great group! Happy New Year to everyone.
Oh comeon!
Probably correct... but I didn't read this as an argument. The take away I got was that different boats with different sails will act... well... differently. Go figure.
Oh yeah and it is white with blue stripes for the main halyard and white with red stripes for the jib halyard...
Oh comeon!
Blues for main sail lines greens for head sail lines - everbodie no dat!
comeon!
I had the same problem until I discovered, every year I was lengthening the rake of the mast to get it up. So I started re-raking it every year to correct, huge difference in tacking and speed.I've often sailed on main only and reefed main only.
typically in winds over 15knts.
its harder to tack. I don't remember trouble close reaching, just stalling if I don't tack with a lot of momentum. then its irons or sailing backwards for a bit, then gain momentum and try again.
under 8knts might be different.
