Portlight
S2 9.2A Ports I replaced the ports in my S2 9.2A with 1/4" Bronze Tinted Plexiglas. I was told that Plexiglas was more resistant to crazing than Lexan. The S2 site says to use sealant to bed the windows, but I used Glazer's Tape instead. It's a neoprene tape with glue on both sides, it's not as messy as sealant and seems to be working just fine. I used 1/8" thick tape, but I think 1/16" might work better. The ports are also through bolted to the structure. There, I used SS screws into SS Tee Nuts that I got at Fisheries Supply in Seattle. They should be available in LA also. No leaks in almost three years. I wrote a longer post on this subject 1-2 years ago, don't remember exactly when, it might be in the archives.
