Hello,I am trying to add some electronics to my boat. I plan on mounting a Lowrancechartplotter at the helm. I need to run 4 cables from the plotter down underthe cockpit. I would like to run the wires inside the steering pedestal tokeep things neat and also to avoid putting a hole in the deck.The boat is a 1986 O'day 35 with Edson wheel. I have a Richie compass mountedon the pedestal. How do I remove the compass? There are two phillips screws that I think hold the compass in. Is that correct? I will need to drill a hole in the side of the steering pedestal to run the wires. The chartplotter uses NMEA 2000, and the wires have special connectors, thatare on the large side. I don't believe I can cut the connectors, run the wire,then splice the connector back on, so I will have to make large (1") holes.Is that true, or can I splice the connectors back on?Thanks,Barry
