I had to cut away the locking discs as they we corroded in place, probably from never be loosened and removed over the years. In the attached photo you will see I have a threaded rod instead of a bolt which ran through the locking discs. One end had a nut which fit into the disc and the other end just had a handle. Can anyone advise what is the rudder made of where my threaded rod is? It seems to be held in by corrosion also. If the penetrating oil does not work my thought is to drill out the threaded rod. Any advise would be appreciated.
