Mike Hollingsworth
Recently I had a problem with my sterring being very difficult to turn the wheel due to resistance. This, I assumed to be a bearing issue because it came on gradually over last summers season. Over the winter I replaced the top rudder bearing (not cheap from Bavaria)only to find that the problem was corrosion that was behind the rudder bearing housing, causing the bearing to compress around the bearing tightly. The corrosion was removed and now the wheel can be turned with one finger.The reason I'm letting everyone know, is due to the fact know one I had talked to at Bavaria dealerships or communication with Bavaria eluded to this potential common problem. Save your money on a German bearing and clean your rudder bearing housing every other couple of haul outs. One rudder nut removal and loosening the quadrant allows the rudder to drop and be removed (obviously not a job while in the water)The problem is usually with the bearing underwater only.Mike
