Two things to consider. One is that you need a lot larger block for the main halyard vs. what you need for a topping lift. If you price the blocks a double big one is going to cost a lot more than a single small one, but maybe you have one.
The other is that....
...the forces on the two blocks are at 90 degrees to each other so I don't think the line would feed as well for the topping lift considering the orientation of the main halyard block. There again the loading is small, so it might work.
With it out on the chicken-head the topping lift is probably less likely to interfer with the sail, but to tell you the truth when our topping lift is slack, like it should be when sailing, it is probably laying on the main. I can't remember, so that must be a sign of that it isn't a problem or I'm not very observant
I'm not that familiar with the 25, is the problem that there is no chicken-head on it?
Sum
[FONT=Arial, sans-serif]
Our Endeavour 37
[/FONT] [FONT=Arial, sans-serif]
Our Trips to Utah, Idaho, Canada, Florida[/FONT]
Our MacGregor S Pages[/FONT] [FONT=Arial, sans-serif]
Mac-Venture Links[/FONT]
