Looking for some input for rig set-up. I have set the rake with forstay for about 10" with no prebend, then set the prebend for 4-6" with the backstay turnbuckles. I have the cap shrouds set at 20%, the intermediates and lowers at 15%. What I see when it is blowing 15knots as I get a puff the mast is moving for and aft a bit due to the sudden pressure from the 155 mylar, not sure if this is normal. Then the back stay is real easy to pull all the way down. I am wonder if the intermediates and lowers should be tighter, will that help with forestay tension. I just picked the boat up this past spring and have won 2 of the last 3 races and just want to get all I can out of her. If I pull doun the backstay will the forestay tension increase?, It appears it does not help much. Are there any mods I can do to increase forstay tension? Thanks for you input..
