Replacing PSS seal
May 16, 2007
1,509
Boatless ! 26 Ottawa, Ontario
I just finished replacing our PSS seal. It was an older model without the vent and hose. It still worked well, no leaks. Rather than just replace the rubber bellows I bought a PSS complete. It was a awkward place to work but it did all come apart and the new components are installed.
I used Maine's suggestion of buying the S/S backing ring from McMaster Carr.
When I did the final adjustment to compress the bellows I positioned the backing ring flush with the PSS seal and clamped it to the prop shaft. I then compressed the bellows and put a 3/4" spacer between the PSS seal and the backing ring. It was then easy to just tighten down the set screws to lock the seal in the correct position. I then removed the spacer, repositioned the backing ring tight to the PSS seal and was ready to install the hose on the carbon ring.
In my case it would have been very difficult to hold the bellows compressed in the right position while tightening down the the setscrews. This ring made the job easy, I was glad he suggested this, thanks !
Bob
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
Ditto
Replaced my bellows last year when I was on the hard for
bottom job and also have the extra spacer.
My bellows was good and no leaks but was about 7 years
old and while out on the hard was good time to change it
also replaced the cutless bearing even thought was not that bad
but changing the bellows meant pretty much taking off everything
off the shaft and also a good time to replace the bearing before really
getting bad,
I did follow Main Sail's web page instructions and made everything so easy
for me first time doing all this and all his helpful tips made it a easy job with
Main Sail"s tips.
Thank You MainSail for all your help
Nick
PS
Did you add the water bottle to the vent hose.
May 16, 2007
1,509
getting bad,
Main Sail"s tips.
Nick
PS
Nick, yes I added the bottle. The boat is not in the water yet so it has not passed that test yet !
Bob
Dec 19, 2006
5,832
Test
Just try to get it high as possible and really only brings in water
when thrown into reverse hard.
Nick
May 16, 2007
1,509
Thanks Nick, I'll see what mine does. I should be in the water next week.
Bob
