Replacement mast shroud
ells
Jun 3, 2004
27
Oday Oday 22 Great Sacandaga Lake
I need to replace a shroud that attaches closest to the top of the mast. Where would I go to find a replacement?
Terry
Shrouds
Try West Marine, they have a center which manufactured my life lines to my measurements and specification.
Steve
I second West Marine
I sent my old shrouds Upper and lower on both sides) via FedEx and West Marine fabricated an exact replacement set. Cost was reasonable as I recall.
F
Fred
Shroud
West Marine very reliable. Be sure to send them your old stay or shroud if you can - that's more sure than relying on your measurements. A local full-service marina may make up new rigging for you or refer you to someplace that has swaging capabilities, BUT . . . make sure they are first class. A lot depends on the integrity of that rigging. Fred
Brion Toss
Details
Hello, Lots of places can make you a good wire; I'll just tell you how we'd go about it in our loft. First we'd make sure that the wire size, terminal size and type, and pin size all made sense in terms of the loads the piece will see. As we say, "Don't clone someone else's mistakes." Then we'd get the LOA, including turnbuckle, after making sure that the LOA puts the mast where it is supposed to be. We'd make sure there were no foul leads, and would change configuration or hardware, if necessary, to get a fair lead. Then we'd deduct for an ideal turnbuckle length, unless we determined that the piece didn't require a turnbuckle (bobstay, springstay, maintopmast stay, triatic, etc.). Then we'd deduct for elasticity. Then we'd have piece swaged up, using rotary swages from a machine that is kept in spec, and would dip the wire in sealant before swaging, to preclude water intrusion. And we'd use a type 316 wire that tested to within 5% or so of 302's rated break. Then we'd install and tune the wire. That's rigging; making a replacement wire is just fabricating. Fair leads, Brion Toss
