So, I asked in a previous thread about the need for the thru-hull for the cockpit and sink drains. I've decided to replace it and parts should be here soon. My new problem is removing the old one. I took the ball-valve and associated hoses off and put a 1' long channel locks on it and couldn't budge it. So I resorted to the largest pipe wrench I can fit into the area. And I still cant budge it. All I'm doing is chewing up the top of the bronze / brass tube and killing myself trying to pull harder (and at the right angle, which is really hard in the space) on it. I spoke to the PO's son-in-law (PO is deceased) and he thinks they worked on it at one time and epoxy-coated the tube before re-installing it.
There's a small 1/8" to 1/4" gap on the outside of the hull, between the hull and the start of the tube (which is what started this whole thing). And what looks like some raw fiberglass just aft of it that I was going to take care of when I removed it and filled the hole with thickened epoxy.
Can I fill the tube and gaps with thickened epoxy and then use fiberglass cloth over the whole thing from the outside? Would heating it with something like a blow-torch work to release it if it is epoxied in? Or. would it just cause more damage? The tube is small enough that I can't really get a saw in there to try to segment it up and get it out that way. Maybe a hacksaw blade working on my back from the bottom, but that would be a real pain in the rear and most likely not help if it's epoxied in. The more I think about it, I think glassing the whole thing over might be the best solution.
Anyone have any suggestions? Thanks in advance. The season is so short up here that I really want to get it in the water before it's over.
