Rick S.
Yesterday I sailed my 170 with the mainsail reefed for the first time. This spring I installed a single-line system to replace the stock two-line setup, and the new rig worked fine. But I hadn't anticipated that to reef, I'd have to pull the retaining pin from the mast track and drop two of the mainsail slugs out of the track. This is a step I'd prefer to avoid, as it requires the crew to stand upright at the mast. (As part of the re-fit, I had moved the cleat for the mainsheet halyard lower on the mast, and installed the cleat for the reefing line opposite it, also low on the mast, so my crew can squat or kneel to use them.) My question: Do those of you who reef your 170 mainsails drop the slugs, or leave them in the track?I probably could have gotten by yesterday without reefing, as the winds were moderate, but as I am still learning the boat I was feeling cautious. I was pleasantly surprised at how much better the reefed 170 seemed to handle overall. The helm was neutral and responsive, the mainsail was managable, the boat pointed well, and suddenly I was a much better sailor. I will add this to the advice of other 170 owners on this forum: when in doubt, reef early, reef often and, if possible, reef before you leave the dock.
