Raw water pump on YSB12 Yanmar
H
Henry Weber
On my 1977H30 the raw water pump started to leak badly. I replaced the seal which stopped the leak but noticed that the shaft was somewhat scored by the old seal. Does anyone know if you can buy just the shaft? Gordon?? Henry
G
Gordon Torresen
Pump shaft
Although not presently in stock, the book shows that the shaft, P/N 104211-42060, is available @ $74.78. If your new seal stopped the leak, wait until it leaks again before installing a new shaft. Its amazing the amount of wear those seals can overcome.
