Raising mast
May 9, 2011
1,000
Hielke van Oostrum
You were asking about raising the mast without a crane.
Albin sold some Vegas with a simple device to raise/lower the mast.
This was on our boat (no. 1492) when we bought it, and I have seen it
on another boat in Ontario. There must be other boats with it,
doesn't anyone else know about it?
The main part was a tubular stainless steel A-frame which could be
left on the boat if you wished, it fitted around the bow, just inside
the stanchions and pulpit. Each "foot" was attached by a bolt to a
very simple fitting at the base of the stanchions which were level
with the mast. In addition, there was a flat hook at the base of
the mast, at the back, which sat on a pin at the back of the
pedestal/tabernacle. It was also necessary to have some kind of
wooden crutch at the stern to hold the mast when it was lying back
along the boat.
With this, my wife and I can raise or lower the mast by ourselves,
and have done so many times. However it helps to have a third person
to watch for fouled wires, and to look after the electrical wires
coming out of the mast.
To raise the mast, the forestay is attached to the point of the A-
frame. The A-frame is vertical in the middle of the boat. The
mainsheet is attached to the point of the A-frame and to some good
fitting at the bow. At this point I get into the cockpit and
provide the initial lift to the mast, as it is hinged at the
tabernacle. That is hard, and it helps if the third person is on the
cabin roof and assists, then takes over the lifting. My wife stands
in the bow and with one hand, pulls in the mainsheet. After I have
heaved it up to a certain angle, she lifts the mast the rest of the
way to vertical. By this time, the A-frame has rotated to lie flat
in the bow.
Lowering it is just the opposite. The A-frame starts horizontal, and
my wife lowers the mast one-handed until I can reach it from the
cabin roof and let the weight down into the crutch.
The equipment does not have to be fancy. One year I was clumsy and
bent a leg on the A-frame so it would not take the load. We put up
the mast with an A-frame lashed together out of pieces of 2 x 4
lumber. Later, had another stainless A-frame made.
There are quite a few things that must be done right with shrouds,
etc. A few years ago, the American Vega newsletter published the
instructions along with my sketches. If anyone wants a copy of
these, let me know your mailing address or fax no.
John
J.B. Sprague, Salt Spring Island, B.C., Flagfish no. 1492
Oct 30, 2019
1,021
Hielke van Oostrum
You were asking about raising the mast without a crane. I tried to
answer before but message must have gone into space.
There was one on our boat (no. 1492) when we bought it, and I have
seen the same thing on another boat in Ontario. The device must be
on some other Vegas, doesn't anyone have it?
The main part was a stainless steel A-frame. It could be left on the
boat if you wished, and it would lie flat on deck in the bow, inside
the stanchions and pulpit. The "feet" of the A-frame bolted to very
simple fittings at the base of the stanchions that were level with
the mast. The base of the mast had a flat hook at the back, which
rested on a cross-pin at the back and top of the
pedestal/tabernacle. There also had to be some sort of a wooden
crutch at the stern to hold the mast when it was lying back along the
boat.
With this, my wife and I could raise/lower the mast by ourselves, and
have done so many times. However it helps to have a third person to
watch for fouled wires and lines, and look after the electrical wires
at the base of the mast.
To raise the mast, it starts lying back in the crutch. The forestay
is fastened to the tip of the A-frame. The A-frame is vertical in
the middle of the boat. The mainsheet is also attached to the tip of
the A-frame, and to a strong point at the bow. I start the process
by standing in the cockpit and lifting the mast and walking forward
to move it up. It helps if the third person stands on the cabin roof
and helps, and then takes over lifting. After raising it a certain
amount, my wife pulls on the mainsheet with one hand only! She
raises it to the vertical position. By this time, the A-frame is
lying flat in the bow of the boat.
Lowering the mast is just the opposite. The A-frame starts flat, and
rises to the vertical as the mast is lowered into the crutch.
The equipment does not need to be fancy. One year I was clumsy and
bent a leg of the A-frame so it would not carry the load. We lashed
together an A-frame out of 2 x 4 lumber and raised the mast with
that. Later, had another stainless one made.
There are several other things that must be done right with the
shrouds etc. A few years ago, the American Vega newsletter
published the instructions with my sketches. If anyone would like a
copy, let me know your mailing address or fax. no.
John
