Steve
When we acquired our 1977 Thames Marine Mirage 28 in February we had water in the bilges, and a little in the bottom of both inside and outside storage lockers. We thought the water was salty. After draining the bilges, hauling the boat in May, and refinishing the hull and keel, we had dry bilges and thought that we had solved the water problem. Three weeks ago in early October it started raining again for the first time since early April. Once again we had water in the bilges and storage lockers both inside and outside, but this time we are certain it is sweet water from rain. We have recaulked around the mast and around the cabin roof, but the water continues to enter. We have checked for leaks by spraying the deck with a hose, but have found no indication of water leaking into any visible area. Another previous owner of a similar, but newer 1982 Mirage 28, told us that he always had a similar problem when it rained. He never found a solution for it other than using his bilge pump and a sponge.Does anyone know how we can stop rain water from entering the boat?
