On the assumption that you have a 2K radar and since one any bigger probably spins, we have that solved. Also the max range of a 2k radar is generally about 16 miles and that is for tanker sized targets. The curvature of the earth is around 8 inches per mile so to be able to see out to the max range of your radar, you need to put it up at least 10 feet on the mast or so. The gotchas are as mentioned above. What you want to see typically is close to you, bouys, jetties, other boats so to put your radar up so high that it cant paint a target in the 1/8th to 1/4 mile range does not make sense IMHO. So up around your steaming light isn't a bad place to start. About 8 feet up from your water line would be ideal but a bit difficult to mount unless you do a pole mount and your jib would probably beat the heck out of itself every time you tack. Also you need to take into account the angle of the mast past vertical due to the design of the boat and rake of the mast. Adjust the level accordingly.
I haven't found myself healed over under sail that many times when the visibility is so low that I need the radar, so a gimbal mount is just a boat bucks option, and Bill I don't mean to belittle your advice at all. My radar world is typically under motor in a sort of 'Hooper and Brody going to find the feeding grounds of Jaws" way.
You can find specs about it from the manufacturer.
Good luck
