VC 17 vs. Micron
I know a lot of People in the Great Lakes use VC-17 and others use Micron CSC. From the Interlux Boat Painting GuideHARD ANTIFOULINGS – The technical term for these types of antifouling paints is ‘contact leaching’.The paint dries to a porous film that is packed with biocides, which leach out on contact with water to prevent fouling growth. This leaching is chemically designed to release biocide throughout the season, but the amount will steadily decrease until there is not enough biocide coming out of the paint film to maintain fouling protection. Once the biocide is exhausted, the hard paint film remains on the boat. Hard antifoulings do not retain their antifouling ability out of the water and cannot be hauled and relaunched without repainting. One of the main benefits of this type of antifouling is its resistance to abrasion and rubbing. This makes it ideal for fast powerboats, racing sailboats or boats where the owners have the bottoms scrubbed regularly. Most hard antifouling paints can be wet sanded and burnished prior to launch to reduce drag and improve hull speed.For Hard Antifoulings ask for Ultra with Biolux®, Ultra-Kote®, Fiberglass Bottomkote®or Fiberglass Bottomkote® Aqua. For Hard Racing Finishes ask for VC® Offshore with Teflon®,Baltoplate, VC 17m® Extra or VC 17m®. 31and for the MicronCONTROLLED SOLUBILITY COPOLYMERS or CONTROLLED DEPLETION POLYMERS – These types of antifoulings are partially soluble which means that as water passes across the surface of the coating, it wears down much like a bar of soap would wear away. The physical action of the water over the surface steadily reduces the thickness of the paint at a controlled rate, which results in always having fresh biocide at the surface of the paint throughout the season. For this reason these types of antifoulings have the capability to perform in the areas of highest fouling challenge.Boats painted with Controlled Solubility Copolymers can be hauled and relaunched without repainting since the biocides are chemically bound to the paint film and are only active when in the water.The longevity of these coatings is related to the thickness of the paint.For Controlled Solubility Copolymer Antifoulings ask for Micron® Extra with Biolux®,Micron® CSC or Micron® Optima.DifferencesHard antifoulings do not retain their antifouling ability out of the water and cannot behauled and relaunched without repainting.Boats painted with Controlled Solubility Copolymers can be hauled and relaunched without repainting I'm just putting this out there for discusion, based on what the Interlux say. I'm not reccomending one over the other.
