An area of visible damage on Avalon is on her starboard toe rail and hull. I'm not sure if the toe rail damage is from an impact, or just wear and tear and exposure to the elements, but I'd like to repair it. Similarly, I'd also like to clean up the areas of cracked paint (gelcoat?) on the hull and the gray scuff from whatever a PO ran into. (I tried to take off that gray scuff with soap and water, but no go.)
I had the bottom repainted this fall, but I believe we can assume everything about the waterline is original.
I don't know much about this type of repair work, so I was hoping someone could give me some starting points and I can go research the rest. The first two photos are of the same area of damage, just from different angles. The third is the hull damage and scuff.
Thanks!
- Andre
Thanks!
- Andre
