Rig Tension
I don't know what your numbers mean. If they are percent of breaking strength, you're 3 to 4 times to high and will end up pulling the deck off the hull.Rig tension is one of those items of minor controversy where everyone thinks a bit different. Tension should be about 8 to 15% of your breaking strength. I tend to like the lower numbers. If Don [Evans] responds....[HI Don!
], he seems to like the higher numbers. In either case, do not tighten to much or you'll induce undo compression forces on the mast, the mast step and on the rig. Just make sure your mast track is straight when you eye the mast, then play with your backstay/forestay tension and mast rake for best performance.The leeward shrouds will be loose will sailing. Whatever you do, DO NOT TIGHTEN THEM WHILE UNDER SAIL. You will damage something. As long as they are not flopping in the breeze, this is not a concern. They do need to be tight enough to keep the mast from imposing a shock load on the rig should the wind [or you
] suddenly shift.Russ
