W
Walt
I have a 1980 Sabre 28 with a Volvo MD7A engine.When I start my engine at the beginning of a trip it cranks strong and fires up immediately. I then go out the channel under power for about an hour before I put up my sails. Duting that time the engine is running fine.I sail for about three hours and then try to start the engine. However, although it cranks strong it doesn't fire up.While cranking, I opened the injectors and fuel is just dripping out. But there does seem to be normal fuel flow into the fuel filter.So in summary, the problem in starting seems to be when the engine is warm, not cold. Any ideas??Walt
