Like pressurized
Granted there are lots of stove options. I give pressurized alcohol high marks in a wide range of areas. Safety is a biggie. Alcohol is way less explosive than the alternatives. So what if pre-heating is the trade off to achieve this feature. I consider it good bargain It is also, as has been pointed out, water-extinguisable. This makes it very easy to douse quickly. A typical stove/sink side by side places your fire extinguisher at the ready, which helps prevent things from getting out of control in the moments you would otherwise be scrambling for a fire extingusher. In addition, you avoid the huge mess an extingusher can make of your cabin and entree.Alcohol burns very clean and sufficiently hot. The fuel keeps well over long periods of time, not degrading into varnishes like petrouleum based fuels.Maintenance is basic and straight forward, very well within reasonable parameters of sailing as a whole. Heck, if I was scared of tedious maintenance, I'd have put as much distance between myself and a sailboat as was humanly possible a long time ago.
