I am removing the positive foam from "Loose Lucy", my O'Day DS II.
Does removing the foam material negatively impact the structural integrity of the vessel?
The (styro)foam is disintegrating and leaving the transom in sm pellets when I open the drain plug, after sitting all winter out of the water the foam is soaking wet, wieghts a ton, it's a bear to remove via the inspection ports.
The online suggestions tell me to replace the old styrofoam with:
childrens noodles
empty 2ltr bottles with sealed caps
Fair Winds,
John McHugh
childrens noodles
Fair Winds,
John McHugh
