There should be a small diameter bolt that slides up from the base of the mast that has a fender washer and a wingnut. Raise the pop top, and push it against the mast. Slide up the bolt into the groove of the pop top, and screw down the wing nut tight. Then your pop top is supported.
That's the simplest way I can think of to describe it
Eric
