Hunter 170 Tuning Guide
Hi all.This is the post that I made on Daysailors Forum, sponsored by Sailing Obsession.Hunter 170 Tuning GuideThere has been questions from Hunter 170 owners, and posted on other forums about what the shroud tension should be on the h-170.I have been in contact with JY about a tuning guide for the h-170. As it turns out, there is none. So, I talked to the lead tech, and they do not use any gages on the shrouds. They just guess.I know, I know. Not a very good plan.I am working on some figures that seem to be promising. I am not done yet because I need to try them out under various conditions. However, I feel the following is pretty close.I am finding that 15% is good for light wind, 18% for all around sailing conditions, and 19% for stronger winds. Remember, within reason, too tight is safer and easier on your boat than too little tension because of "shock load". Also, the higher the tension, the better you point because of the tighter forestay. And with lower tension, the better your down wind performance in light wind. There is a trade-off.Also, some have suggested that a mast rake of 15% is needed. I disagree. A mast rake of 1.5% is best on a "mast head" rig. The h-170 is a "fractional rig", and I feel, it is better to have bit closer to 1% mast rake. In addition, if the mast is raked to 1.5%, then you will find that you have to much "weather helm". The following are my evaluations at this point:Mast Bend: 1% of mast height from head to boom. Example: h-170 mast = 24’1” (289”)Mast head to boom = 19.75’ (237”)237” x 1% = 2.37”1/8” cable breaking strength = 2100* 1/8 “ @ 2100 lbs. x 15 % = 315 lbs. --------Masthead rig, to prevent to excessive mast bend use only 15 %.* 1/8 “ @ 2100 lbs. x 19 % = 399 lbs. --------Fractional rig w/swept back spreaders, tangs even with forestay.The lower shrouds are much more variable. I am finding that if you have upgraded to a Boom-Kicker and an 8:1 vang, then you can have a very light tension on the lowers. I like about 50 lbs., (measured with vang off).When you put on a lot of vang with an 8:1 and the B&R rig, that adds a lot of tension on the lowers.When I am completely satisfied with my figures, I will forward them onto Hunter. Hopefully, they will add the information as an amendment to the h-170 manual.Danny Hartzell
