90 from tack to tack sounds good, John
John,By slightly better than 90 degrees I assume you mean 45 degrees off the wind. Then with a tack, you've made your angle from stbd. tack to port tack a full 90 degrees? Do I have that right?If so, I think 45 degrees off the wind is very, very good. Whatever you're doing to attain that- stick with it.I'll definitely send an update after a year or so with the Compac 19, but right now I must say I love it. We took her for our maiden voyage yesterday in 15-20 knots of wind without even thinking about reefing the main or the 130% genoa. My wife and the dog took a nap below on the v-berth while I singlehanded. I think we caught some gusts above 20 knots and I just headed up slightly and put her back on her feet. Although she never really heeled past 5 or 10 degrees. The 40% ballast on the boat is a little unreal to me as a neophyte to this boat. In this wind on the 170 I'd have been sailing reefed main only- no jib.I didn't see a big sacrifice in speed with this added heft either. Looking to daymarks/fixed channel markers along the way- and past them to land, I was very satisfied with the headway we were making. Broadreaching seems like her fastest point of sail, by a nose. But closereaching and running are pretty quick too. Wing on wing running with the 130% jib gave some serious oomph. The one drawback to the setup (the genoa sheets to the outside of the shrouds and the shoal draft keel) is that the boat will not point quite as high as a 170, or a Cal 24 or other, speedier, deeper draft keelboat.I'm extremely pleased with the Compac now, and predict same for a year from now. When I step aboard-- 160 lbs., 5' 10"-- she barely moves under my weight. This stability will serve us well as we take weekend cruises and longer occasional trips. At this phase in life I was ready to trade some responsiveness for a much steadier ride in a blow and a relatively large cabin (for barely a 20 footer) and a head! I'm going to write a little more about my first impressions in the "Adieu from a former 170 sailor" post on this site.Happy sails to all,Mike G.s/v Freebird, Compac 19/2
