Trying to install an under-sink Pentek slimline filter canister to the cold water tubing that exists as installed by the factory. Obtained 1/2" pex tubing and push on fittings, but the factory installed grey tubing looks very slightly smaller than the 1/2" pex tubing, and when I disconnected it at one T-junction it has a molded bulbous end like the flared end of a brake line - see pics. Is there anyway, ie what kind of fittings to adapt the two types to each other before I go and cut the tubing that was factory installed?
Thanks. Ilan
Thanks. Ilan
