TimC
I need to drop the rudder on my Pearson 30 to inspect/replace the bearings and other parts that might be causing some play in the rudder. I read on the web that the rudder of a Pearson 26 cannot be removed when the boat is on stands unless a hole is dug below the rudder. Reportedly, the P26 rudder was easily removed when the boat was in a cradle. Is the P30 the same? I cannot dig a hole in the marina's asphalt. Does any know if the rudder of a Pearson 30 can be removed when the boat is on stands?Thanks.
