We have a '90 Passage 42. Does anyone know how the hot water lines are run on this model? All I can see is it exits the water heater and disappears under the hull pan. Somewhere, the line has blown open and we're pumping water under the pan which then flows in to the keel sump through limber holes. I fear I will have to cut the liner to get to the hoses for repairs but would like to know where the hoses run before I break out the angle grinder.
Thank you in advance,
John
John
