Stimpy, that pump on the wall is most likely the
pump for a Lavac marine toilet. http://www.lavac.com/ It doesn't macerate, it's either a manual or electric diaphragm pump. And there's no reason TO macerate waste before it goes into the tank...nor to macerate tank contents either. Solids are 75% water and are broken up by the toilet pump...and they dissolve very quickly in water. The tank installation described in the article is prob'ly the "K.I.S.S" system, first suggested by Charles Kanter about 10 years ago. All the waste goes into the tank...at sea the thru-hull is open to allow it pass through...in coastal waters, the seacock is closed. The tank can either be pumped out or dumped via gravity at sea. You can read all about it here: http://www.sailcopress.com/editorial%20MSD.htm I'm not a fan of this system...it's simple, but it's not unusual for the tank discharge line to become clogged with sludge. And, because the tank is above the toilet, there's always standing waste in the toilet discharge line as well as in the tank discharge line. As for tank material...the seamless rotomolded PE is the only recommended material for waste holding. No metal of any kind should ever be used to hold sewage, and bladders are also a bad choice...ok for water, but not for sewage because they have relatively short lifespans, are prone to blow out fittings are the first sign of a blocked tank vent, and--because they're designed to hug to the contents--it's almost impossible to eliminate odor out the vent every time the head is flushed. Unvented bladders cannot be used for waste holding...CG regs require that all tanks used to hold sewage or gray water must be vented to the outside of the boat.I suggest y'all check out Ronco Plastics http://www.ronco-plastics.com (no relation to the VegoMatic Ronco)...they make top quality rotomolded PE tanks, and have more than 400 shapes and sizes, over 100 of which are non-rectangular. And they install fittings in the sizes and locations specified by the customer when they make the tank. If you can't find one on their site that'll fit your space, the only other good choice is a welded plastic tanks...and there are a couple of mfrs who make good quality custom welded tanks for a reasonble price. As for how to install a system that'll be easy to maintain and odor free, y'all might want to check out the link below.
