I have the Isomat NB-26 boom on my P303 with internal reefing and outhaul. I'm trying to determine the routing of the reefing lines. The outhaul is straight forward I think. It’s wire at the clew with some kind of pulley system inside and line at the tack through the middle of three clutches. I'm assuming the reefing lines are for the clew only as there are hooks for the tack. There a couple of things I don’t understand. The boom has two external sheaves on the starboard side which look like they coincide with the reefs and several eye straps spaced out down the boom that look like they hold line, but I'm not sure how they are included. It also has two exit plates, one on each side about one third the way down from the gooseneck and with cleats for each. A third cleat is on the underside which I assume is for the outhaul. If anyone has a similar arrangement and can shed some light on the best way to rout the lines it would be appreciated. Paul P303, #224
