Hi all, I'm needing a little bit of advice. The problem is that my 1985 90 hp Johnson motor needs an impeller. And I can't raise the motor from down to do that. They hydraulics sound like they are going, but no movement... And I tried using a large board, and ropes and pulleys and things to lever it up and out, but no luck. It only moved maybe 2 inches. I can't see anything that could be holding it back. I would rather not pay somebody to haul her out of the water to just change the impeller, what are my options? Any advice? Things I may have overlooked? Thanks! Ian
