Original Keel Turning Ball + Question about Keel Cable Hose
Mar 31, 2019
64
Catalina 22 12640 Rose City Yacht Club
Hi all,
Tonight I replaced the keel lifting hardware on my C22 since I was fairly certain it was very old, if not original. I'm using the CD kit. Sure enough, the keel turning ball looked as if it hadn't turned in years. I'm not sure how well this will come through, but the left side of the turning ball in the photo is clearly worn through.
Question about the keel cable hose: I'm replacing the keel cable hose as well. Does this get glued onto the volcano with something like 4200? Or are the hose clamps sufficient to keep it sealed?
Thanks!
Andre
ShawnL
Jul 29, 2020
106
Catalina 22 3603 Calumet Mi
It generally gets installed with the 2 supplied hose clamps -- one to keep the water out and the second as a backup to the 1st. I had to heat the hose up with a heat gun to get it to go on the volcano. Though a pot of hot water would have probably worked just as well.
Mar 20, 2015
3,094
C&C 30 Mk1 Winnipeg
Volcano pipe is double clamped with 2 hose clamps Put the gear adjustment on opposite sides.
Similar to other hoses attached to seacocks.
I check ours regularly.
One day in my fantasy world of additional free time, I plan to make an emergency wood bung/plug for it, just like you would for seacocks.
AaronD
Aug 10, 2014
723
Catalina 22 9874 Newberg, OR / Olympia, WA
As usual, @Maine Sail has a relevant article. Worth reading. The hose clamps in the Catalina Direct kit are good quality. If you need to replace them, be sure to buy good 316 SS non-perforated ones.
In addition to the volcano, we have the cockpit drain and a (non-functional) speed log paddlewheel, so 3 through-hulls in that area. I keep a tapered wooden plug and a length of bicycle inner tube there (twist tied to something, so they stay put, but should be easy to release if needed). I've had no need to test it, but I saw a recommendation that wrapping inner tube around a leaking pipe (e.g. the volcano hose) would slow a leak. Seems sensible and worth having around. Also, I keep a stubby hammer to pound in the wooden plug (in a big ziplock with my rigging cable cutters and a bit of dessicant). That serves my paranoid tendencies.
Likes: Leeward Rail
Jul 11, 2019
4
Catalina 22 Lake Conroe, TX
You do not need the seal the hose with sealer. The two clamps provided by Catalina are of high-quality. When I had trouble getting mine over the boat fitting, I used dish soap inside the hose. Make sure you get it down as far as it will go You should put the clamps on as previously stated with the clamp screws on each side of the hose, just make sure that you have them low enough on the hose so they squeeze the hose to the boat fitting. Hopefully you are doing this in conjunction with changing the centerboard winch over to the new style if you have an older boat. The spindle on the original Catalina winch was too small in diameter and caused the cable to “fishhook” and then ultimately break from being bent too much over the smaller spindle.
  • Helpful
Likes: AaronD
Mar 20, 2015
3,094
C&C 30 Mk1 Winnipeg
Interesting info. Any idea what years that was ?
Mar 20, 2015
3,094
C&C 30 Mk1 Winnipeg
They sell non perforated 316 stainless clamps for automotive performance/racing use . I found them cheaper than "marine" sold ones. Just make sure they are the same spec.
Jul 11, 2019
4
My boat is a 1972. You could call Catalina tech-support and they could tell you when they started putting the updated keel winches in Catalina 22’s. The original spindle was a small diameter. As you can see from this picture from Catalina Direct the center spindle on the new keel winch is larger in diameter The new one cost about 180 something dollars. You will also need a new cable.
Mar 20, 2015
3,094
C&C 30 Mk1 Winnipeg
Yup. Ours is a 87 new design. I didnt realize Catalina changed the winch over time. I havent seen it mentioned as a "new Design" change so i am guessing it happened much earlier.
Mar 31, 2019
64
Thanks for the guidance. The PO replaced the original winch with the CD winch a few years before I bought her, so I'm in good shape there. My primary motivation for replacing the lifting hardware was that the pendant attached to the aft end of the keel was bent in a way that I wasn't comfortable with. And the hose seemed very old/original.
