OkI bought this boat sight unseen from the Greatlakes and trucked it to Va.Supposed only problem was prop shaft seal.I am handy so no biggieAfter making a new shaft, painting, cleaning, fixing the wiring, and rebuilding the water pump.We sat it in the water, started to sinkOpps, cracked HullI have it running and in the local MarinaIt runs well, changed points, plugs, head gasket, opened up water hose pipe size into the block, flushed etc.It quits running after about 1 hour out, slowely loosing power untill it quitsput put miss miss put put untill she fadesThe exh looks like its blowing some steam, I replaced the tem guage and have the engine running at 135 it was previously at 155 F.HelpThis boat has me baffled, and the tax man thinks its worth 15kWith taxes like this and problems that I can not solve, it may sinkThanks in advancedhoodenpyl@aol.com
