O
Olivier Ruhlmann
Hello all,My O'day 37 is a 37 model. I know the core material is foam because I have had two experiences drilling throught the deck:I have installed a propane locker in the cockpit seat and had to cut out a fairly large section of deck (where you seat in the cockpit). The foam was dry and bright pink!I then repaired two through cracks near the main hatch. Again, I dough out a fair amount of the same bright pink foam.I was surprized when I installed a pedestal bar in the cockpit floor and saw that it was cored with wood!I guess my boat was an experiment!!!Francois: I don't understand your question about the genoa track. My track is not designed to drain. I have not had any problem with the track holding up water?...Olivier
