Oceanis 351- Cleaning fuel tank
Jan 6, 2014
35
Oceanis 351 Helsinki
Hi,
How have you cleaned the fuel tank of 351? Is there a service hatch?
Previous owner had never cleaned it up ( for last 20 years) and I think this should be done/checked.
sailrj
Jun 16, 2004
43
Beneteau 351 0 Aurora, KY
The fuel gauge sending unit port is what I have used. Remove the sending unit , being careful to not strip the screw holes or damage the gasket. I pumped the diesel as low as possible with a 12 volt utility pump and sucked some trash out with it and then finished the job with the vacuum container that I change oil with. Treat the tank with a good slug of biocide in the day before you clean it will help break loose any algae and help with the clean up. If you can't get every thing out, the empty tank can be remove relatively easily. Good luck.
Hi,
Apr 14, 2010
195
Jeanneau 42DS Larnaca Marina
My 381 had a 1/4" plug at the lowest point of the tank. So last time I cleaned the tank (when it was empty) I replaced the plug with a fuel valve and stuck a short vinyl hose at the end of it. Once in a while I drain the bottom of the tank in a small bottle to get any water or dirt out. Learned that from my piloting days...
Lee
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
Lee
i wondered when someone was going to say this...thats a very good idea...we did this every time we preflighted the aircraft on the flight line
