are not very accurate. For those of you who read my other post (to reef or not to reef), you know that I decided not bring my Mac 25 Deep Blew 6 hours up Chesapeake last Saturday due to a small craft advisory. It turned out that the advisory should have been posted for mid to late afternoon (as per THECUSCOUS, was sailing along my planned route that day), and not the full day. Regardless, I decided to bring the boat up today (played hookey from work), due to a great forecast - 5-10 kts steady winds building up to 12 kts in the late afternoon, partly cloudy, 61 F. And the best of all, we would be on the run most of the day. That last one was the most accurate of the forecast. The waves started at 1.5 ft (not bad), but at 10 am wind was already at about 10 kts. Because we were sailing on the run, I was using my 130% genoa as a reacher. At about 11:30 the wind was at 12-14kts and the waves built up to 2-2.5 ft, so I dropped the genny and was sailing under a full main, when we got hit by a 22-25 kts sustained gust. I don't know about some of you claiming it's a great fun to sail in those conditions under a full sail - you must be nuts! Under the main alone the boat started heeling at about 45 degrees and I couldn't control the heel since we were on a broad reach! I quickly rounded the boat into the wind and 2.5 foot waves and we dropped the sail. (the attached picture is of the following seas just before the gust - you can clearly see white caps and a 2-foot wave chasing us). Luckily, I kept the motor running, so we had some steering left. At that I asked my wife to check the forecast, and was astounded that another advisory was posted due to possible 25 kts gusts. The wave forecast was also revised. The gust lasted about 10-15 minutes, after which I put up a reefed main and a 100% jib and had plenty of fun surfing down the waves. But, this was a lesson - do NOT trust the NOAA forecasts - always listen to the weather radio when underway...
