New to the forum & new to sailing
Apr 25, 2015
282
Oday 26 Oscoda, MI
Hi everybody. Great site and hope to learn a lot here and have millions of questions. I just bought a 1985 26' O'Day and a 36 foot slip for it to sit in on the Great Lakes. I have owned many power boats but not a sailboat..until now. I originally bought a Precision 165 and was going to lease a slip but I couldn't pass up the great bargain on purchase of the 36' slip so decided to go bigger for easy weekend stays and longer if wanted. Preceision 165 is up for sale now. Now for work on the 26' and finish before it gets too late in the season (only a 5 month season here).
First thing I am going to do is pull the entire head system out and install a new porta-potti with deck pump out. Pump outs are free at the marina since us owners own the pump out system so I am not worried about a weekly pump out fee. So here is my first issue I need to deal with. I need to pull the old gate valves attached to the thru-hulls and cap the thru-hull for now. I know the proper way to do this would be to either glass the holes over or install a true seacock to the new thru-hulls however I just want to make it water tight for now, sail this summer and do the thru-hull with seacock or glass over during the winter months.
I need to powerwash the bottom and wipe with the 3M scotchbrite pads and secure the port side chainplate better. Starboard plate was secured by PO by using two pieces of marine plywood, stained and laminated and glued to each side of the bulkhead with the chainplate inbetween. Not my favorite way of doing it but will do the same for the port side and then pull the bulkheads during the winter and replace them and do the chainplates the correct way. For this summer I will also apply butyl tape around the chainplate base on the deck to help the water leakage issue. The port side is not really that bad at all however it wiggles just a tad on deck and I won't chance it.
Then comes electrical. PO didn't believe in the words "Tip Top Shape" but I do. Wires running everywhere with none of the ceiling lights working. I hope the wires are still good to the lights and then install a new circuit breaker panel and wire those up up again. PO was using velcro push LED lights--UGH! Then for the depth finder...PO cut the tranducer wire when he install speakers on the cockpit wall. I hope to be able to fix that.
Wash and wax the sides, install new state boat stickers and clean everything up and hope to launch however, my one and HUGE worry is the mast stepping procedure. The P165 I bought of course is a breeze for one in mast stepping but the 26' O'Day is entirely different due to size and weight so I need to figure this all out and soon. 83 here tomorrow--would love to be on the water even if I look like Curly of the 3 Stooges out on the water sailing for my first time.
Oct 13, 2013
182
Wayfarer Mark I GRP Chicago
Welcome to the hobby/passion/sport/obsession of sailing! I am new as well. Down in Chicago so I know your pain of the short season.
I can provide some advice on the mast stepping. For a 26' I personally would go the way of paying a marina to step and rig it for you. Getting the tensions right and managing the weight of the mast as it goes up is well worth the cash.
If you are set on doing it yourself look into the Gin Pole rigs that have been build (what I did) and it makes stepping it so much easier. I know some people do it solo, but I think it is at least a two man job even with the rig. I liked it much better when there were three handy. Built mine for < $100 (good line, trailer winch, u-bolts, carriage bolts, and a few 2x6).
Feb 17, 2006
5,274
Welcome to SBO. You will find here tons, and I mean TONS, of information from how to scratch your head when you have a problem to how to solve the problem. All you need do is just ask.
If you look at the very top of the page you will see the SEARCH tab. Use it and abuse it. When you have a question seek the SEARCH tab and ask there first. If you do not see your answer then post it on Ask All Sailors.
Looking forward to hearing of great sailing adventures from you.
Apr 25, 2015
282
Oday 26 Oscoda, MI
Hi there, there you happen to have any photos od drawings of your Gin pole set up?
Apr 25, 2015
282
Oday 26 Oscoda, MI
Thank you and I will for sure use the seach first.
Ward H
Nov 7, 2011
3,786
Wind, Welcome to OdayOwners.com!!
Great site for information.
Oct 10, 2009
1,044
Catalina 27 3657 Lake Monroe
Welcome to sailing! It sounds like you have a good list to work through; focusing on those holes in the hull is wise. Lots of us have dealt with the bulkhead/chain plate issue. It's really often not a matter of if they need replacing, but when. Not a difficult task, but obviously very important. Having your mast straight up and down rather than laying over the side of your boat makes for much better sailing.
