need hull measurments
Sep 9, 2015
3
Oday 272 LE erie
Oday 272 le,
I need hull or trailer measurements for bunks or support post. This is the second trailer I will be making for a 272. I sold my original with the boat when I decided to go bigger. Now I realized my loss, and bought another 272LE, and need a new trailer,but I didn't keep my original measurements I took to make the other one. Boat is several hours away, so I cant take measurements. What I need is a height from the bottom of the keel to the top of each support, and then the center line of the keel to the length center line of the post. An example would be......6 supports..... 2' height centerpost, on center of keel...3 feet from center line of keel.
front support 34"height, 3' from center of keel..2' from center line.
My supports will be adjustable by up to 16" and from center, but I need a starting place.
:confused: PLEASE HELP!!
Sep 9, 2015
3
Oday 272 LE erie
Additional, if needed, I can provide drawings for cradle or trailer for a o'day 272 or 30 !! Please help, I've calculated measurements on the upright supports, but with only 16" of adjustments, I would rather have them confirmed before I pick up the boat! Mobile crane time is very expen$ive to be adjusting up on the fly.
May 14, 2014
7
Hunter 28.5 Lake Michigan
Hello jgrimmjs,
I also need this info. I am planning on using 6 screw jacks and would like to have a good staring point.
Did you have any luck in getting this info?
