Motor bracket weight limit
Apr 14, 2021
74
MacGregor 26D Mobile
On my 26D there is a swing down motor bracket. I do not see a manufacturer on it anywhere. What would be the max weight it should support. It has a 1992 Yamaha ft9.9 that has minimal use but seems a good bit on the heavy side.
I had a Honda 9.9 on my H26 when I bought her. I swapped it out for a Tohatsu 6. The 6 will drive my boat at hull speed at 3/4 throttle.
Nov 30, 2020
79
Macgregor 22 Dania, FL
My bracket came with springs. Did yours? If so, pushing down on the springs should give you a guesstimate of weight capacity. Springs should balance or raise motor.
Chip V.
