I am rewiring the mast. I have an anchor light at the top, a steaming light 1/3 the way down and a deck light midway between the spreaders and the base. This is all original on the mast. I will replace the anchor and steaming with new Aqua Signal 25 series lights. There is an existing two prong plug at the mast base for connection to a deck mounted receiver with wiring inside connected to a OEM panel with one switch for the mast light. I am trying to find information on the wiring diagram for three independently run lights. I believe that I can have a common ground for all three lights, but I need separate power for each light (or is that the reverse?). So how do you run the power into the boat and to the power source (battery)? I think I need a new mast plug (four prong) and two new switches in the boat to control the lights. Is this correct? What else am I missing? Thanks
