Hi all,
I'm in the process of removing all deck hardware, potting the holes and re-bedding the hardware.
My question regards re-attaching the mast plate. It was secured with 4 machine screws into the deck (the large aluminum backing plate). Do you all feel this is adequate, or should I through-bolt it when I re-attach it?
Secondly, any good way to remove the silicone caulk the PO used so I can bed the hardware with butyl tape?
