Sav'h Steve
Mast Pipe Insulation Install:I had an idea for installing the pipe insulation. I bought it yesterday at Home Depot. They had two choices rubber and polystyrene. The cheaper styrene looked like it would crumble as it ages. I opted for the rubber, but it is like a wet noodle and most likely would not push into the mast.So I decided to tie a heavy sinker and SS washer on the bottom end of a fishing line to drop down the mast. Then tie a knot 2” from the end of the first piece of insulation, running it to the end and tying a second knot, then attaching the second piece butt end to the first. I’d tie a another knot 2” from the end to secure it to the first piece and pull the two pieces so that the end of the second piece is about 3-4 feet from top of mast to allow room for the foaming insulation. Then I’d secure the end of the fishing line to the top of the mast. I would leave the line in just in case I would need to remove for any reason.Many thanks to Glenn for the original idea.Steve
