Help please.
I need to replace the main sheet block, swivel cam cleat (there is probably a technical name for this assembly that I don't know) on the port aft of my Mac 25. I am unable to access the underside in order to place nuts and washers due to location. I doubt anyone has arms long or skinny enough to make that reach. The original was loose enough and unable to tighten that I was able to get a hack saw between the mounting base and the mounting surface to cut the bolts off. I know I don't want to use plain screws to reinstall since it is under considerable load at times. What are my options? Is there a type of expanding wall fastener that can be used here, or a threaded insert that can be installed that will hold up? Previous owner had moved main sheet control blocks up to the stern rail to get it above the Bimini Top that he installed. (and perhaps because the lower installation was shot. I would like to return it to the lower location.
