Below is a post of mine from a couple of weeks ago. It rolled off into the archives so I've quoted it below.This past weekend I replaced the 7/16" jib and main sheets with 3/8". As expected, it's harder on the hands but all in all I think the reduced friction is well worth it, especially for the mainsheet. When I ease the sheet, the boom moves out even in light air. No more pushing the boom.The whisker pole works well! I only had it up for about 5 or 10 minutes but it's a great addition.--- original post ---Submitted by Rick Macdonald on 08/11/2005 at 08:54AM regarding General_interest.My used boat came with 7/16" main and jib sheets. I needed to replace them both with longer lines and got the same diameter.I'm thinking of downsizing them (next smaller size would be 3/8") for various reasons:Main:Lots of friction. I have to push the boom out in anything but heavy air. The upside is that with that much friction I can often sail with the main uncleated. Seems like a saftey feature in a way, but I'm thinking it's becoming tedious to have to push the boom out.Jib:1) I have an option to buy a Forespar 6-12 ADJ-DL whisker pole but the end fittings are too small for my large jib sheets.2) I suspect that the Spinlock PowerCleats on the jib sheets will work better with a smaller diameter. The large diameter changes the angle of the internal cam cleat. I think this may have contributed to breaking one last year.3) Friction could become a problem in very light air as the jib sheets get older and fuzzier.What size lines do you all use?...RickM...
