I cleaned the keel 2 years ago. The keel had 4" of growth on it.
I cleaned the keel, went down to metal and then high pressure kind of material for removing rust. Then I covered it with a metal paint to keep the water and rust off of the keel.
The keel has stayed the same for the last two years. It has a few rust lines but nothing important.
My only problem in the knocking noise I get from the keel. I was thinking about taking it out again and then glassing the upper part of the keel so it will fit the gap perfectly. However, I worry about making it too wide.
My current thought is to use the plastic from a kitchen cutting board. If I place a cutting board on each side and glue the boards to the sides of the gap I would reduce the amount of moving sideways space of the keel in the gap. The plastic is not as hard as fiberglass and if something gets into the space it will cut right through the plastic and not freeze the keel. I can replace the extra liner space each year and end up with a keel that will not make noise as pressure hits from different directions. Plastic can be purchased at different sizes and it can be shaped to fill the gap space appropriately.
Is there a problem with this idea?
What glue would you use to hold the plastic in place?
