Hello,
Got a 2GM20F which has been working fine for the short time i have had the boat. But last weekend when turning the ignition on, i did not get the low oil pressure alarm beep which disappears when the engine fires. There is a check switch on the panel and i get a beep from the alarm when i click this, so there is not a problem with the speaker. I have checked oil level with the dispstick and this seems fine. I am guessing it is the oil pressure sender but before i change this i thought it would be worth checking using my multimeter.
What test can i do with my multimeter to show that the sender either is definitely is working, or definitely isn't working?
Thanks
Mick
Thanks
Mick
