Advantages of the Loose Foot
Hobbyking,The only pro I can think of for a standard foot main is that you can sit on the boom without falling through. I tend to recommend loose footed mainsails in most cases. There are a couple of reasons for this. Since the loose foot is a simpler setup it is easier to trim. By tensioning the outhaul the foot of the sail is able to be pulled absolutely flat. On mains with an attached foot, there is usually some 3D curvature designed into the foot of the sail so that it can have a reasonable shape just above the boom but still return to the straight line of the boom groove or track. Pulling the foot tight will minimize, but not totally eliminate this 3D curvature. This is the reason that in the old days racing mains used a flattening reef, which tensioned the sail on a line just above the foot curvature(these days amost 100% of racing mains are looe footed). Conversely, when you want to make the main fuller and more powerful there is no limitation as to how full the loose footed main can get, since there is no cloth holding it to the boom centerline. Also, a loose foot mainsail is easier to bend on to the boom. It also affords much more flexibility when rigging such thing as, reef lines, jibe preventers, vangs and other things that require tying a line around the middle section of the boom. I would suggest you stick with a loose footed mainsail. Thanks,Bill ColomboDoyle Sails
